Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Can't Receive Incoming Call
  1. #21
    It is port 5060 all the way through to the epygi unit.
    I have checked and is 5060 as they ports for SIP on the unit.
  2. #22
    When I telnet to the device, it gives a black screen, but unless the quadro responds to these requests I wouldn't expect to see a hello or anything like you get with SMTP servers.
    What logs would I expect to see the telnet request, to double check?
  3. #23
    If you can telnet to 5060 - it means te port forwarding for TCP most probably works. But it gices you nothing, as you cannot make calls with TCP (can you make your ITSP call using TCP?).
    You need to make sure the UDP 5060 forwarding is done too. For that you can try to register a phone as a remote extension on <yourRouterIp:5060> so it will send a REGISTER message to Quadro. Then check in Quadro registration logs whether the message was received..
    Or another way - use some tool (for axample, "Essential NetTools", or XSpider) to generate UDP packets from outside to <your router's IP>:5060 and capture all packets on the Quadro (netcapture.cgi). If UDP forwarding on router works, you should be able to see your packets in the capture (view that using Wireshark/Ethereal).
  4. #24
    you can make calls, but you cannot recieve.
    im just throwing a stone in the bush here
    i had the same problem and it was actually a simple rule in the routing table the cased the problem
    where did you specify the incoming itsp call to go to?
  1. Dial out while receiving a incoming call
    By andy.collins in forum General Discussions
    Last Post: 01-21-2014, 01:32 AM
  2. problem with the incoming call
    By newworld in forum Troubleshooting and Problems
    Last Post: 09-03-2007, 11:03 PM
  3. What’s BEST - route incoming call
    By megatron in forum Installation
    Last Post: 10-23-2006, 10:18 AM
  4. VOIP incoming call goes to ext 11
    By etolentino in forum 'How Do I' Questions
    Last Post: 08-21-2006, 09:56 PM
  5. Rem Etxs: Call in OK, but can’t receive
    By uspnetworks in forum Troubleshooting and Problems
    Last Post: 08-13-2006, 01:25 AM
