I noticed that Quadro 2xi become unstable after I installed v5.
Some times when we try to call someone using our SIP route it says without any single second delay:
IP Connection cannot be established.
I open command prompt and I ping the SIP server. Everything's fine. I open a softphone and Im trying to make a call using this SIP server. Everything's fine.
I run diagonistics tests on Quadro, the network is just fine.
So, I have to reboot the device to make it work.
Today I had to reboot the device again. After reboot I was unable to call again. Now without a message but a continious busy tone. I tried to login to the Quadro web interface and when I enter username and password the internet explorer loads for ever... I can't see the menu.
I had to hard-reboot the device (plug out the power cable). Now the admin interface opens but I still cant call. Continious busy tone on the SIP route.
Generally, the Firmware Version: 5.0.17/Release I have installed its very unstable
I can go back to the latest 4.x ?
