Results 1 to 10 of 18
Thread: Put 2 phone numbers on the same phone
    I would like to put 2 phone numbers on my receptionist phone but i don't konw how
    You can attach more than one IP Line to your receptionist phone by comma separated IP line numbers. If you want to attach IP Line 2 and IP Line 3 then type 2, 3 in Attached IP Lines field of receptionist wizard.
    Hope it helps,
    Souren
    thx it's running but i've another problem : i can call external phones and be called by external phones only with one of my number and not the two.
    The IP Lines are attached to some extensions besides receptionist phone. Now please describe whether that extensions are registered on some SIP server or not?
    Souren
    Edited by: souren
    I've registred IP Line 1 and IP Line 2 with the same phone in Line parameters.
    In Extension Management, I've configured IP Line 1 with a SIP number and IP Line 2 with another SIP number and i've click on "Registration on SIP server".
    For the IP Line 2 in the beginning i've configured a phone(Aastra phone)with a SIP number and after i've put this SIP number on the receptionist phone (Snom)
    In Receptionist Management , i've put in Line Attached "1,2".
    There is only one of the two phone which can call and be called by external calls.Only internal calls run with the second phone.
    I hope i've explain what you wanted to know
    PS: i'm sorry for my english ^^
    If both lines are successfully registered on your SIP server you should be able to make or receive calls. You can check this from System -> Status -> SIP Registration Status.
    I suggest you to submit TSS case, download system logs and attach there so we can take a look on your configuration.
    Souren
    What do you call "TSS Case" ??
    If you login to techincal support area you will see Request Form.
    I don't have Request Form that's why i came to this forum.
    I've searched this Request Form because i see it in the help menu but i don't have the link.
    What browser you are using? Try to clean up the cache.
  1. Ring multiple PSTN numbers at once
    By stakano in forum Suggestions and Feedback
    Last Post: 02-24-2011, 11:51 PM
  2. Porting Numbers
    By andy.collins in forum Tips and Tricks
    Last Post: 12-09-2010, 06:18 AM
  3. MS Outlook phone numbers can not dialed
    By Internet in forum Troubleshooting and Problems
    Last Post: 10-23-2006, 10:53 AM
  4. Call Hunting with External Numbers
    By threebit in forum 'How Do I' Questions
    Last Post: 06-27-2006, 01:57 PM
