Thread: pin protect specific numbers
    Default pin protect specific numbers
    it is possible to pin protect specific numbers in an extension? for examples all mobiles: 69* ?
    Sure, you can set Local Authentication on the routing rules.
    You would need to configure the PINs in the "Call Routing"->"Local AAA Table" (add users with "Authentication by login").
    After adding those PINs (users), go to Call Routing Table and edit the needed rule and set the "Local Authentication" on the "AAA Required" group in the CR Wizard.
    After that you can can see the "Users List" in the "Local Authentication" column of the Call Routing Table on that rule. Click to that and enable the needed PINs for that rule.
    Please ask if somethin is not clear.
    I want to edit the rule 0?* which is the NDS: 1 - ISDN trunk: Any Port(User), but it doesnt have the checkbox to edit it
    Yep, you cannot edit that. It is system rule which you created when passing through the "System Config Wizard" and selecting the "0" as "PSTN Access Code"
    If you want to edit tat rule, pass through that Wizard again, and select nothing as "PSTN Access Code". The rule will disappear. Then you can create your own rule like that one, and set anything you want...
    Nice trick! thanks
  1. How to choose a specific extention to park a call on
    By woods in forum 'How Do I' Questions
    Last Post: 05-12-2014, 09:53 PM
  2. Porting Numbers
    By andy.collins in forum Tips and Tricks
    Last Post: 12-09-2010, 07:18 AM
  3. Little help Please - SIP numbers
    By Brent Simpson in forum General Discussions
    Last Post: 08-19-2008, 06:51 AM
  4. MS Outlook phone numbers can not dialed
    By Internet in forum Troubleshooting and Problems
    Last Post: 10-23-2006, 11:53 AM
  5. Put 2 phone numbers on the same phone
    By hgttelecom in forum 'How Do I' Questions
    Last Post: 06-25-2006, 05:57 PM
