Thread: Call Routing
    Default Call Routing
    I've got a problem with call routing
    i set all incoming calls to route to 301
    Route 301 is setup ->301 NDS: 3
    Prefix: 42
    PBX
    None
    Acc.
    [Mon-Fri][08:00-17:00]
    Check with 3PCC: Disabled
    10
    Day Service
    and--> 301 NDS: 3
    Prefix: 43
    PBX
    None
    Acc.
    [00:00-23:59]
    10
    Night Service
    MERG 42 will ring exts 221, a loud bell and 227, the swb
    MERG 43 will ring exts 221, a loud bell and 227, the swb, and 228 after hours ext
    the problem i have if someone phones in, the line will ring once then the system will say "the number you have dialled does not exist"
    i then have to change tie fxo settings to ring ext 227 and then change it back to route 301 to resolve it.
    only one or two lines at a time will do this, different lines at different times.
    this causes me to test the lines every hour to make sure the routing works.
    in the CRT do the following :
    table number 2./ ( or one that is high on the crt list )
    pattern ?? call type pbx that should solve your problem....
    If i am right you dont have an entry for 2 digits to be passed to the extension table and that is why you get the message as you are getting.
    i've got ?? for the call routing and ??? for the local exts
    the above mentioned routing wirks, it just gives me the error every now and then
    The other thing you need to do is to remove the night time schedule and leave it as the second route then when ever your day route is not active it will go to night time... or make a third route.
    Quote Originally Posted by cornepiek View Post
    Corne, does the problem happen on onboard FXO lines, or only with the virtual FXO lines (FXO lines from the FXO GW)? This could be a problem specific to FXO GW lines...
    will this also cause problems with the speed dial setting in the routing table through the gw??
    Sure, it could.
  1. PBX-Voicemail call routing enhancement
    By harryb in forum Suggestions and Feedback
    Last Post: 09-16-2008, 09:34 AM
  2. call routing
    Last Post: 04-20-2008, 09:25 AM
  3. IVR to call routing table
    By andy.collins in forum VXML Scripting on Quadro
    Last Post: 10-02-2007, 07:24 AM
  4. Prefix Tag on call Routing
    Last Post: 06-27-2007, 10:09 PM
  5. Call routing based on incoming DID
    By wesleyit in forum 'How Do I' Questions
    Last Post: 12-03-2006, 02:15 PM
